Cooler For i7 4770 - No overclocking?
Go to solution Solved by Loe,
Alright thanks for all the responses, I feel I have enough information to make a decision now.
I was thinking of getting a Hyper 212 Evo but socket 1150 isn't officially supported.
I have a micro-atx case so can't have a massive cooler, max height is 160mm.
CPU: i5 4430 PSU: XFX 550w Ram: 8gb Patriot Viper 1600mhz
Motherboard: MSI H87M-G43 Case: Fractal Design Define R4
SSD: 840 Evo 250gb, 512gb MX100 GPU: MSI GTX 980TI Gaming Cooler: Hyper 212 Evo
https://linustechtips.com/topic/41957-cooler-for-i7-4770-no-overclocking/
It should support it. The 1150 shares the same as the 1155 to my knowledge.
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
I was led to believe that 1150 sits slightly lower than 1155.
Make sure you get the hyper evo 212+...Thats the one they released that supports haswell completely I think
I am good at computer
Motherboard: Gigabyte G1 sniper 3 | CPU: Intel 3770k @5.1Ghz | RAM: 32Gb G.Skill Ripjaws X @1600Mhz | Graphics card: EVGA 980 Ti SC | HDD: Seagate barracuda 3298534883327.74B + Samsung OEM 5400rpm drive + Seatgate barracude 2TB | PSU: Cougar CMX 1200w | CPU cooler: Custom loop
Strange. Well either way that suggestion @SSOB said is very well done. BeQuiet as he said are dead silent.
Get a bequiet dark rock 2 , it's just so silent you can hear yourself breathing rather than the cooler itself. And it looks nice.
Actually i can safely say ALL the bequiet coolers are Excelent in performance and silence just pick the one you like the most :
http://www.bequiet.com/en ( It's a german company and you know german cars they are the most reliable things ever , the volkswagen TDI engine is just a BEAST )
Interested in Business and Technology
Ha nice mention on the cars XD But all in all BeQuiet are very nice. Cheaper than Noctua for same great preformance.
Can't find it.
Stock?
I'm sure stock would work fine, just looking for other options at the moment.
I'll take a look. Will have to take your word about the engine thing :P
You live in the USA lol you dont even know how cheap bequiet is over here in the EU in germany you can get a dark rock pro 2 for like 60 euros . But still it's also a great value in USA as well of course :P
Ivy and Haswell uses the same mounting for heatsinks. All heatsinks that works for LGA 115 also work for 1150.
Also the Hyper 212+ and Hyper 212 Evo are two different coolers.
You don't need an aftermarket cooler if you're not overclocking. You don't need to worry about noise if you have good case airflow.
Some people do care about astheathics you know. I know you are not big into astheatics but that doesn't mean other people aren't.
Whats your decision if i may ask :P ( i hope this isn't rude or something)
It's fine :P
I haven't made one yet sorry.
Yeah I know. It's just that with my bit of information, the OP can go ahead and get whatever looks good and not worry about not having enough cooling.
