How does software versioning work?
Dobbsjr
It's common consensus, but all depends on company developing software. They decide format of version string and when project reaches alpha, beta stages. Even in company I work, we use multiple formats for different projects.
@Dobbsjr follow your own topics to get notifications
I am sorry for my english.
There's no set standard for versioning which is fine because not all software can be versioned in the same way. A common one like you said is major.minor.possibly another minor.revision. The major version goes up when you have a lot of changes or say a few very large changes, minor goes up when it's a few small changes and revision is just the revision of your code repo. The second minor revision is for tiny changes like hotfixes. The revision of your code repo is very important because by looking through the revision history you know exactly what code you deployed.
This style is very common because it works for a lot of software projects. However it differs between companies and teams within those companies. For example, there are some teams within my organisation that seem to just use 1.major (stupid IMO) and one of the applications my team develops is year.month.revision, e.g. 15.6.49607 is the June 2015 release at code revision 49607.
Alpha and beta are very different and well defined terms. Alpha testing is carried out by the testers (this could be another role of the developer) within the company in a controlled environment to test for functionality and any low hanging bugs. It's not open to anyone outside the organisation. Beta testing on the other hand is performed by the end users of the product. This might be an open beta for a game where anyone can try it out, or it might be a group of developers at the customer trying it out. At this stage it will undergo testing in something that is supposed to approximate a live environment although you can rarely get close to that, think about how many games have server issues on launch because you can't stress test your servers with that many people in a beta.
As has been said, there isn't really any set standard and you can basically do what you
want. There are also rather esoteric version numbering schemes out there. For example,
Donald Knuth uses pi as his versioning system for TeX, adding ever more decimal digits
to each version. A neat gimmick, but not necessarily very useful if you want to actually
extract information from the versioning number, at least as far as I can tell.
There is the concept of semantic versioning though, developed by one of the co-founders
of github (though I'm pretty sure the general concepts behind it have been around longer,
I reckon he's just the one who finally put it in a systematic coherent form and gave it
a name), which is laid out here: http://semver.org/
The fundamentals are:
Given a version number MAJOR.MINOR.PATCH, increment the:
  • MAJOR version when you make incompatible API changes,
  • MINOR version when you add functionality in a backwards-compatible manner, and
  • PATCH version when you make backwards-compatible bug fixes.
Additional labels for pre-release and build metadata are available as extensions to the MAJOR.MINOR.PATCH format.
You can read more about its finer points on its website. As said though, even this
is not a god-given standard, it is something which has had a lot of thought put into
it, but that doesn't oblige you to follow it.
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
On wikipedia it says version numbers work somewhat like this: major.minor[.build[.revision]], but what counts as a revision and what counts as a revision? And when is it appropriate to say a certain software is alpha or beta?
the software maker decides?
Semantic Versioning
This is the scheme I prefer. Frequently, software versions are meaningless and thus useless because the developers follow no guidelines, or if they do they aren't documented.
I think it differs with software.
Personally for me, while developing a program I made called LightningLaunch, the Alpha stage was when there was the most bugs. After the majority of those were sorted out, I then moved into the Beta stage, when there was much less bugs, and started allowing people to use the program.
As for the versioning, a whole number would usually mean lots of new features implemented, and decimal numbers would mean user-suggested features and assorted bug fixes and enhancements.
I've attached below a screenshot of my program's version history, which says the version and what features were changed/added along with it.
Speedtests
WiFi - 7ms, 22Mb down, 10Mb up
Ethernet - 6ms, 47.5Mb down, 9.7Mb up
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
 RAM             8GB CORSAIR XMS3 (2x4gb)
 Cooler          LC Power LC-CC-97 65W
 Motherboard     ASUS H81M-PLUS
 GPU             GeForce GTX 1060
 Storage         120GB Sandisk SSD (boot), 750GB Seagate 2.5" (storage), 500GB Seagate 2.5" SSHD (cache)
Type            Server
OS              Ubuntu 14.04 LTS
CPU             Core 2 Duo E6320
RAM             2GB Non-ECC
Motherboard     ASUS P5VD2-MX SE
Storage         RAID 1: 250GB WD Blue and Seagate Barracuda
Uses            Webserver, NAS, Mediaserver, Database Server
Quotes of Fame
On 8/27/2015 at 10:09 AM, Drixen said:
Linus is light years ahead a lot of other YouTubers, he isn't just an average YouTuber.. he's legitimately, legit.
On 10/11/2015 at 11:36 AM, Geralt said:
When something is worth doing, it's worth overdoing.
On 6/22/2016 at 10:05 AM, trag1c said:
It's completely blown out of proportion. Also if you're the least bit worried about data gathering then you should go live in a cave a 1000Km from the nearest establishment simply because every device and every entity gathers information these days. In the current era privacy is just fallacy and nothing more.
