What areas are overclocking best for
I know gamers like to overclock a lot but are there any other reasons people overclock and why is overclocking so popular.
Thanks in advance
it fun, your pc goes faster.
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
Okay, so you generally overclock CPUs and GPUs to get more operations per second, and maybe RAM to get faster speeds.
More CPU power means that you can do any CPU-based task quicker, while more GPU power will generally mean that you can run games at a higher framerate, among other things.
Sig under construction.
Thanks in advance
Overclocking is its own game, its very enjoyable for me at least since I mainly do GPU benching.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
how much more performance can you find by overclocking about 700-1000 MHz?
Take performance of the card and the amount of megahertz it's running at.
divide the megahertz you're adding by the card's clocks speed
Now do 1+(proportional increase that you just calculated)*performance numbers
should roughly equal overclocked performance.
Could you show an example, I don't quite get you. Sorry
GPU with 1000MHz clock speed gets overclocked to 1500MHz (so a 500 MHz or 50% overclock) 50% because 500/1000 = 1/2 or 50%
If you previously got 40fps in a game, that overclock would (theoretically) result in your getting 60fps in a game. 1000/1500 = 40/60
Remember that this math is very theoretical though. There are other factors that play a role in the performance of a game, so it is unlikely that this would give you that exact increase in performance.
CPU: AMD FX-6300 4GHz @ 1.3 volts | CPU Cooler: Cooler Master Hyper 212 EVO | RAM: 8GB DDR3
Motherboard: Gigabyte 970A-DS3P | GPU: EVGA GTX 960 SSC | SSD: 250GB Samsung 850 EVO
HDD: 1TB WD Caviar Green | Case: Fractal Design Core 2500 | OS: Windows 10 Home
will my cpu die sooner because of overclocking? I mean a lot sooner
I mean, is there a visible performance increase or is it all just benchmarks.
encoding videos. lots. and lots. of videos.
TTC follows a roughly linear correlation with OC vs. stock (depending on the software).
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
It depends upon what you're overclocking (CPU, GPU, or RAM) and what program you're using, but it does give you a visible performance increase.
