SSHD is better than HHD ? in term Speed or long time durability ?
Solved by Captain_WD,
Hey there Raghav Arya,
SSHD drives are basically regular HDD drives (most commonly spinning at 5,400 rpm) with a small SSD portion (most of the times 8GB in size) that is used for caching. The drive usually has an algorithm that figures out what are the most commonly used applications and files (such as the OS and applications that you work with/games you play) and stores their loading files on the SSD so it can read them much faster when launching them. Everything else loads pretty much as fast as on a regular drive.
These drives are pretty useful if they are used on computers that run just a few programs most of the times (office machines, gaming computers, etc.) so the drive knows what is used most of the time and loads it faster. The down side is that you have no control whatsoever over what goes to the SSD portion and if you use several things on the computer you never know what will load faster and what won't.
In terms of reliability, they should last just as any regular HDD, but they have an additional point of failure (the SSD portion) which theoretically increases the chance of the whole drive failing.
Captain_WD.
