Building my new machine will be complicated? or not?
Solved by C0LL0SS0S,
Hey Trauni, most german name I can think of, if you are really serious about your creating content on your PC with Adobe products, I recommend X99, otherwise the 4790k witht the 980ti should really drive the games you want to have, plus its well within the budget, get a 500GB SSD if you ask me since some video files can get a bit larger ^^
eviohh ·
Posted in Troubleshooting2 -
5
IhateAMDDRIVERS ·
SashaSanguine ·
Posted in General Discussion6 -
9
Redsin ·
Posted in Graphics Cards3 -
BTSHalfLifeAndGmodFan2003 ·
Posted in Graphics Cards12 -
1
3
2
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
