Is my pc build correct and balanced
Go to solution Solved by stconquest,
@Ethan supabass
I made a small mistake on the motherboard.  It was fine, but was missing one thing:  a USB 3.0 header.  You could use it, but the front USB 3.0 port on the case will not be USB 3.0 compliant.
I switched it up a bit.
$1037 before taxes:
CPU: Intel Core i5-4430 3.0GHz Quad-Core Processor  ($235.48 @ Newegg Canada)
Motherboard: Asus B85M-D PLUS Micro ATX LGA1150 Motherboard  ($59.99 @ Memory Express)
Memory: Patriot Signature 8GB (2 x 4GB) DDR3-1600 Memory  ($54.41 @ DirectCanada)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($58.95 @ Vuugo)
Video Card: Sapphire Radeon R9 280X 3GB Tri-X Toxic Video Card  ($279.05 @ Vuugo)
Case: Thermaltake Versa H22 ATX Mid Tower Case  ($42.55 @ DirectCanada)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($38.99 @ NCIX)
Operating System: Microsoft Windows 8.1 (32/64-bit)  ($107.92 @ shopRBC)
Case Fan: BitFenix BFF-SCF-12025KK-RP 43.5 CFM 120mm  Fan  ($5.54 @ DirectCanada) <<Front intake
Monitor: LG 22MP55HQ-P 60Hz 22.0" Monitor  ($138.88 @ Canada Computers)
Total: $1027.30
Generated by PCPartPicker 2015-06-02 01:16 EDT-0400
!HELP ME PLEASE :( !
I am getting into pc gaming and I came up with a pc build. I have already chosen the parts for my pc, because this is my first time building a pc, I am not sure if i am doing this right.(also my build is over my budget and my goal is 1000$)
Here are the parts that i have chosen to put in my pc: :unsure:
Gpu-
http://www.novatech.co.uk/products/components/nvidiageforcegraphicscards/nvidiagtx980series/gv-n980ggaming-4gd.html
GIGABYTE GV-N980G1 GAMING-4GD GTX 980 4GB 256-Bit GDDR5
450$
OR
MSI GeForce GTX 970 GAMING TWIN FROZR V OC 4GB GDDR5
280$
Cpu-
Intel i5 4690k
219$
6991d6776ac97e4ac89e46ba5055b675.med.256
OR
Intel i5 4690k
176.5$
f6776a85afe4c2236d84eb42fe6da169.med.160
Ram-
Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory
50$
192486a00fc269b983a3cbdb2904666e.1600.jp
HDD-
48$
4ec3ca6eb2e3bde32b760483f1988fb0.1600.jp
Motherboard-
MSI Z97-GAMING 5 ATX LGA1150 Motherboard
135.5$
61f8ff960037cd1b618eb3d5d461f05b.med.160
86.5$
773a2495b6bc59205e0b503165008fd7.med.160
Case-
NZXT Phantom 410 (White) ATX Mid Tower Case
80$
b0e0a66e2f0b59f4d90b98690e294ac1.1600.jp
Cooling-
Phanteks PH-TC12DX_BL 68.5 CFM CPU Cooler
59$
113a2198b3e5dffa7b5af1e988f3d0fc.med.160
PSU-
650W 80+gold
65$
ssd-
Kingston Digital 60GB SSDNow V300 SATA 3 2.5 (7mm height) Solid State Drive (SV300S37A/60G)
40$
Windows-
Code
34$
Screen-
ASUS MX279H 27-Inch Screen LED-Lit LCD Monitor
180$
Total price:~1225/1147.5/1313.5
Budget:1000:(
Please help me find where i can cut down the price and tell me if I did everything correct. :)
Well, you need to get a cheaper GPU to get to $1K, like a GTX 970 or an R9 290/x. Also, never use AMD for gaming, they're okay, but an i5 will be way better in terms of gaming performance.
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
Cpu will bottleneck the shit out of that gpu
EDIT - That's better. There was an 8370 on there
Intel Core i7 9700k - EVGA FTW GTX 970
Drop the 980 to a 970, and switch out the CPU and motherboard for an i5-4690, i5-4690k if you want to try overclocking. And any motherboard that is Z87, or Z97.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
This would be a much better solution for 1080p gaming:
The GTX 980 is really not needed.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.98 @ NCIX US)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($31.24 @ Amazon)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($122.99 @ SuperBiiz)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($49.99 @ Newegg)
Storage: A-Data Premier Pro SP900 128GB 2.5" Solid State Drive  ($59.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($51.49 @ OutletPC)
Video Card: EVGA GeForce GTX 970 4GB ACX 2.0 Video Card  ($329.99 @ Amazon)
Case: Corsair Graphite Series 230T Black ATX Mid Tower Case  ($69.99 @ Amazon)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.99 @ Amazon)
Total: $1005.65
Generated by PCPartPicker 2015-06-01 18:43 EDT-0400
ssd is the slowest and 128 is really the minimum for ssd's nowadays.
Definitly not.
no. cpu will bottleneck the shit out of the 980.
making you a list right now
Thanks
I reallty want that gtx 980 but for the budget, cpu will bottle neck that gtx 980. I'll think about it. ty
I knew it :(
but i am already over budget
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($176.98 @ NCIX US)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($84.98 @ OutletPC)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($68.99 @ SuperBiiz)
Monitor: Acer H236HLbid 60Hz 23.0" Monitor  ($149.99 @ Best Buy)
Total: $1053.27
Generated by PCPartPicker 2015-06-01 18:47 EDT-0400
considering that you needed the monitor with the budget
low as I can go for a great experience for gaming
windows can be bought for 15 dollars in www.reddit.com/r/microsoftsoftwareswap very use to do. i can help you on that
Guys!! The i5 4460 is not much more and maybe less that that amd cpu. Get the 4460 and an lga 1150 mobo and keep it the same price.
 Just because you don't care, doesn't mean other others don't. Don't be a self-centered asshole. -Thank You a PSA from the people who do not say random shit on the internet.
Got it. i will change it
Points in agreement with folks in this thread:
-You really need to reconsider the AMD CPU. It is simply not enough for the GPU you are selecting or most modern games. That chip would work ok if you were only planing on older games at medium to high settings, but you're selecting a GPU that can push that way further
Points in disagreements with folks in this thread:
-I think that with a 1k budget you should keep the 980. Take The Witcher 3 for example. This is a game that is out right now and even at 1080p the 970 cannot max all settings and achieve 60 FPS, the game is simply too demanding already for that card with Hairworks enabled even at 1080p. Most will say that a 980 it's overkill for 1080p but it wouldn't surprise me that a year from now most games would be on the level of Witcher 3 and henceforth the card would be a lot better than the 970 in the long run.
Important point:
-You can always save some money and build a solid 800 to 900 system with the 970 now but leave yourself open for a second 970 SLI down the line. That's a more sensible choice if you can't make an i5 and a 980 work in your budget (and it would be tricky to be honest)
Minor point:
I don't really like that case and it's expensive, this one is cheaper and looks better imho the NZXT S340:
Current Rig
$998, sorry no SSD:
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($173.95 @ SuperBiiz)
Motherboard: Gigabyte GA-B85M-GAMING 3 Micro ATX LGA1150 Motherboard  ($41.98 @ Newegg)
Memory: G.Skill Sniper 8GB (2 x 4GB) DDR3-1600 Memory  ($49.99 @ Newegg)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card  ($324.99 @ Amazon)
Case: Thermaltake Versa H21 ATX Mid Tower Case  ($32.99 @ SuperBiiz)
Power Supply: SeaSonic 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($64.99 @ SuperBiiz)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  ($87.98 @ OutletPC)
Monitor: Asus VN248H 23.8" Monitor  ($129.99 @ Newegg)
Total: $958.35
Generated by PCPartPicker 2015-06-01 18:54 EDT-0400
You should also get some case fans.  Two in front for intake, one in the top as an exhaust:
Case Fan: Cooler Master R4-C2R-20AC-GP 69.0 CFM 120mm  Fan  ($4.99 @ NCIX US)
Case Fan: Kingwin CF-012LB 40.0 CFM 120mm  Fan  ($3.98 @ OutletPC)
Total: $13.96
Generated by PCPartPicker 2015-06-01 18:59 EDT-0400
Well, at first I forgot the monitor...
So, this is a bit... interesting, let's put it that way.
The point behind that build is, that you overclock the shit out of that little CPU.
It's enough for most games right now and in the future you can upgrade to an i5/i7.
The R9 290X from Sapphire delivers definitly enough performance for any game right now at 1080p, and there was even enough money left to squeeze your monitor into the build.
BUT... The CPU is only a dual core. It does definitly not deliver the same performance as an i5. Even overclocked you'll have problems running too many programs. If you keep your harddrive clean from junk and overclock it to the max, you'll get at least a really good gaming performance out of it.
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($91.55 @ Amazon)
Video Card: Sapphire Radeon R9 290X 4GB Tr-X OC Video Card  ($299.99 @ Newegg)
Monitor: Asus MX279H 27.0" Monitor  ($252.72 @ Amazon)
Total: $971.94
Generated by PCPartPicker 2015-06-01 19:04 EDT-0400
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor (£176.34 @ Aria PC)
CPU Cooler: Phanteks PH-TC12DX_BL 68.5 CFM CPU Cooler (£35.97 @ Overclockers.co.uk)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard (£89.99 @ Novatech)
Memory: Kingston Fury White Series 8GB (2 x 4GB) DDR3-1600 Memory (£46.79 @ Amazon UK)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive (£41.94 @ Aria PC)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card (£263.99 @ Aria PC)
Case: NZXT Phantom 410 (White) ATX Mid Tower Case (£69.98 @ Novatech)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply (£63.31 @ Amazon UK)
Operating System: Microsoft Windows 7 Home Premium SP1 OEM (64-bit) (£67.95 @ Ebuyer)
Monitor: Asus VE278H 27.0" Monitor (£148.98 @ CCL Computers)
Total: £1005.24
Generated by PCPartPicker 2015-06-01 23:59 BST+0100
$998, sorry no SSD:
Total: $958.35
Total: $13.96
Are u sure the mother board isn't cheaped out if not then I'll go with this one. thank you
100% guarantee that the kid is now confused.   G3258, build in GBP.  Go for a 980, don't go for a 980.
He needs Windows (f*ck your redit bullshit), and a monitor in a $1000 build (USD).
It is what will work.  It has everything you need.  The reason it is cheap is that it is an entry level 1150 motherboard.  There is nothing fancy about it.
Important point:
Minor point:
Thank you but about the case; the cheapest one that found is only 5 dollar cheaper. and the case that i got is better for it's price. sorry.
Markham, Canada.
Oh shit.  You are not getting that build for $1000... I live in Toronto.  Let me try another setup...
Total: £1005.24
will it bottle neck if I keep the gtx 980
