Search In
  • More options...
Find results that contain...
Find results in...
How hot is too hot for a CPU
It's summer. The air is hot and the pc gets crazy hot. What temp is considered to be too hot for a CPU? I'm trying to figure out if my CPU is overheating. Thanks in advance guys.
A CPU should not get hotter than 100 degrees celsius although higher temps can be sustained for limited amounts of time. Haswell for example should be able to tolerate 110 while Ivy Bridge could tolerate 105.
It should be noted that you should sustain as minimal a temperature as possible with good ventilation throughout the case as other parts can fail at lesser or greater temperatures.
Remember, your PC is only as good as it's weakest part.
EDIT:
I want to add that Intel does have temperature specs for each processor. The steps can be found in the FAQ here.
A CPU should not get hotter than 30 degrees celsius although higher temps can be sustained for limited amounts of time. Haswell for example should be able to tolerate 45 degrees (110 Fahrenheit) while Ivy Bridge could tolerate 40 degrees (105 Fahrenheit).
What?
Ignore this post I quoted. It has been corrected. The person merely got their temperatures mixed up.
"It pays to keep an open mind, but not so open your brains fall out." - Carl Sagan.
"If you place a piece of bread somewhere on Earth, and another one on that point's antipodes, well you made yourself an Earth-sandwich." - Michael from Vsauce.
Wrong, wrong, and wrong
Intel CPUs have a max core temp of over 90C(the point where they start throttling), but you should keep them in the 70C-80C range.
I prefer to keep my i7 2700K in the high 60s but it should not be damaged even at 80C+
it will help if you tell us exactly what CPU you have.
I am not sure about AMD CPUs.
CPU: AMD 3950x Mobo: MSI B550 RAM: 32GB DDR4 GPU: Asus 3080 Strix PSU: Superflower Leadex 3 720w Case: BeQuiet 500DX
Storage: 2TB SSD + 4TB HDD Audio: SMSL 793ii -> HiFiman HE-400 + Mission MS-50 Speakers
OP - If you're running Haswell try to keep your temps below 90 C while under full load. Try to keep them below 80.  What type of temps are you getting?
Not sure about AMD CPUs.
For AMD CPUs, I think it's around 62 degrees C. At least before throttling begins.
Whoops, sorry guys! I got my degrees all mixed up! Post corrected.
Still the same.
Edit: Never mind.
65 degrees ;)
| CPU: INTEL i5 6600k @ 4.6Ghz @ 1.328v | Motherboard: ASUS Z170-AR | Ram: G.SKILL 2x8GB 2400Mhz | CPU Cooler : Corsair H100i V2
| GPU: GIGABYTE GTX980Ti G1 GAMING | SSD: SAMSUNG 840 EVO 250GB  Storage: WD 1TB GREEN | OS: Windows 10 Pro 64bit | PSU: FSP 650W AURUM S |
<<<<< BLK-Phant0m >>>>>
every cpu got his max temp like
core i5 4670k his max temp is 72
just google it and you will find some good answers
for me the max temp is 76
Manners Maketh Man
 Share
