Search In
  • More options...
Find results that contain...
Find results in...
weird Dxtory problems please help me out
dxtory decrease my fps drastically this is ss of one least demanding cs 1.6 game. in more demanding games everything is worse. like minecraft it drops below 30fps while recording. down below is a video. and trust me i dont crank all the settings up. and even if i did it would be too bad to record
specs are
4690k @ 3.9ghz
r9 290 vapor x
16gb ram
and 320gb drive @ 46mb write(and i tryed to record on to ssd with 457mb/s write and no change)
all drivers blah blah blah
this video is perfect example of my problem.
https://www.youtube.com/watch?v=hk2SaNdmR3M
ps this is brand new world
well if your going to uplode to youtube you wont need more then 60 FPS anyways if your going to upload it to the net no point in haveing it passed 60 fps try lowering setting on dxtory
well cs is just a test even minecraft drops from 120+ to high 20ies imagine me playing battle field or other demanding game. its just gonna destroy all the fps
As far as i know a small dip down in fps is acceptable but men youre talking like you having serious issues
Could you please upload a photo of your' dxtroy settings cause i had the same issues while using dxtroy (so i started using fraps)
here is the link for image with all the settings http://www.part.lt/img/b4908ed3f30f99e63926770c44a4411a924.jpg if it doesnt show up press reload
i have serious problems just look at it...
Oh my god you got serious issues there
What i can tell is that this might be caused by 2 things
either the hdd write speed is low (which from what i saw isnt)or its a program error
Fixes;try using dxtroy video codec and change quality preset to YUV24 (what would help me a lot to detect youre problem would be to install fraps and see if you have the same framedrop)
please let me know.
please let me know.
now i played arround with dxtory and cs 1.6 more and i figured out one thing i was filming a cheater but stupid move i have set 720p as resolution witch it was default and messed up recording
but what is really WEIRD that there is command developer 1 witch allows 250fps instead of 100 and guess what hapened from 60ies it went up straight to 125 average. problem solved you may ask? NO its not supposed to eat fps like that. on the other hand bandicam doesnt decrease fps dxtory one report 90 instead of 100 and ingame frame meter is about 99 instead of constant 100 but what i can see on the screen is 30fps because is not smooth. how do i capture a video with out a major fps drop?
https://www.youtube.com/watch?v=QU4svlLP2hY
sorry for the focus my nexus 5 camera is horrible
What i can see is that it drops fps because it is trying to compress the video to 30fps
If you really like i can give you a link to download a full version of fraps from my personal dropbox account otherwise you can use microsoft expression encoder 4  (lower quality than fraps) please let me know what you prefer
I will be HAPPY to help you
I will upload a video of my personal settings see if doing whatever i have done will help the situation
I use 4 out of my 8 threads https://www.dropbox.com/s/38ugi40kpi2p8je/ScreenCapture_11-5-2015%204.58.00%20%CE%BC%CE%BC.xesc?dl=0
MAKE SURE THAT YOU MATCH YOUR SETTINGS WITH MINE
no..
Do you have 1 HDD? If so, how much SSDs or HDDs?
Also how much space and how much space left.
Be specific about the HDD or SSD.. Model etc.. NOT OVLY WESTERN DIGITAL.. WD what?!
NETWORK IT
no..
ssd .5 TB crucial m550 m.2 interface hoocked throw adapter via sata
and hdd 320gb hitachi model (hdt725032vla380)
hdd has like 100gb left and ssd 2gb coz i filled it with video like 80gb of raw fotage
get raptr running (instal it) , or dowload OpenEncodeVFW encoder for AMD gpu's and set that as a Codec inside Dxtory
CPU : i5 4670k @ 4.2Ghz | Cooler : NH-D14 | GPU : Sapphire Radeon HD 7870 [OC] | MB : Asus Z87-Pro | RAM : A-DATA 8GB 1600Mhz CL9 XPG Black | SSD : 850Evo 250GB
Would you like to tell me if you want fraps or if you saw any difference using my settings
THANKS
I've had the exact same thing. I found dxtory works perfect for some games like BF4/Hardline, GTA 5 then I have to use fraps for things like minecraft. I just switch between what works best for different games
Am suggesting him if he wants the full fraps
he ain't answering
THANKS
sorry i was offline for a bit. your settings helped a bit but as i crank resolution file size gets hunagous and still it drops my fps by 20-50% but its a bit better
thank you for the suggestion :)
he ain't answering
i have full fraps im pretty sure i tryed fraps and it seems like fraps take away 40% of my fps while dxtory 35%
So my final conclusion is that it is a glitch with linux cause windows work just fine.
I really dont know what you can do about linux, i personally dont use linux for anything else than backtrack but for gaming and recording they might have issues and bugs.
What are you planning on doing
Let me know
