HELP! I am a complete newbie to computer building and I want some advice!
Solved by grayblizzard,
HELP! I was just wondering if anyone can give me some advice on what parts are needed to build a good gaming computer. The only part I have is the case but I may want to upgrade that in the future. If you could let me know what the parts that I will need to build my pc and the minimum amount of $AUD I will need to spend that would be great!
txmatt1214 ·
Posted in New Builds and Planning1 -
2
2
Nevan Nedall ·
Posted in New Builds and Planning7 -
3
Littellittel ·
Posted in Troubleshooting0 -
4
ShadowBroker50 ·
Posted in CPUs, Motherboards, and Memory0
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
