test to see if the cpu runs at it's propper speed
Guest Haduvokone
Go to solution Solved by StainlessSR,
the extra L3 cache per core and hyper threading (depending on the game and/or program you are using) would be worth it to me. That would equal about 130 usd (cheaper than a new I5), and a friend of mine in germany sent me a link to the eu amazon where they are going for around 213-280 eur.
Sounds like a winner to me as long as you are not expecting huge improvements from this upgrade.
Oke i had a lot of problems latly with my bottleneck around my 3570 i5 and my r9 290 no sorry it's nothing with temps or so evrything fine it's really really strange but anyway does anyone now a good program too see if my cpu runs at the right speed because it does runs on the right frequincy but maby with points so i can compare it well to see if it is really good and there is nothing wrong with it?
Try CPU-Z.
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
Try CPU-Z.
i use occt, benching too.
http://www.ocbase.com/
Ya know.... that I5 isnt bottlenecking that 290 and vice versa...
My Main Build: NZXT S340 - NZXT Kraken X31 - Crucial MX100 256GB - i5 4460 - Gigabyte Z97P D3 - Kingston HyperX Red 8GB - MSI Nvidia GTX 780 3GB - Corsair LL & HD RGB Fans, Corsair Lighting Node Pro.
How do you know the 3570 is bottlenecking the 290?
well in bf my gpu usage is around 50 to 100
Stress your CPU using Intel Extreme Tuning Utility and monitor your clock speeds using CPU-Z.
can i also do it with the jams software stress test? i already have that
That's fine. As long as the CPU is being pushed to 100%.
actually it's called heavvy load
it's does 3,55 ghz
it's does 3,55 ghz
The CPU is definitely not the problem. Do you get any kind of fluctuation?
How do you mean?
How do you mean?
Do the clock speeds bounce at all? Like, from 3.5GHz to 800MHz(these are just examples. Not necessarily what one would experience).
no it does bounch around from 3,5 to 3,7
now it has stabalized at 3.7
Did you overclock your CPU at all?
no is there something totaly wrong then?
no
The CPU shouldn't be hitting 3.7GHz if all cores are hitting 100%. It should be staying at 3.4GHz.(the stock speed is 3.4GHz)
but with turbo boost right?
oh i am such a stupid kid o mean i cloud just kick my self to hell it fluctating from 3.54 to 3.57 o i am such a n00b
Have you checked your GPU temperatures?
yep max 73 degrees c i think it's over for me :(
Uninstall your graphics drivers and install them again.
