thoughts on triple 24" 1080 monitors
The thing that I am trying to think about, with a higher resolution, don't you get slightly better detail, even with lower settings? I guess it's really one of those things a person needs to see up close, in real life.
I just want triple monitors so bad, it looks like amazing good fun.
I've always wanted triple monitors too.
But I think detail will be the same on the single monitor, considering per monitor you get the same amount of pixels as currently.
But you will have a wider FOV will means you can see more on the screen. The detail might be better because you will have a smaller FOV 'per monitor' thus having more pixels displaying certain objects, if you understand what I mean.
But there are cons to triple monitor setups too.
I speak for Battlefield 4 (I absolutely love the game) and know the scaling on it is good (despite what that JayZTwoCents vid says). Check out the other games on the widescreen gaming forum (link next paragraph) to see how they do scaling in widescreen. BF4 got a gold rating. Also, Nvidia's surround setup I believe is better than the eyefinity one by separating each monitor into its own unit, and then putting most of the UI for games on the centre screen for easy access (don't quote me on this, I'm pretty sure this is different from eyefinity, but again I'm not sure).
But in all, I really want to have a triple monitor setup, regardless of what others say. I think the surround gaming experience is so immersive (I've tried it a couple times) and it makes it feel all that more realistic. If you're serious into getting into triple monitor gaming be sure to check out the widescreen gaming forums and
I do think though that some $200 monitors might pose a problem. To take full advantage of the experience of widescreen gaming, you need frameless monitors, which will typically cost more than that. Also, with 4k coming into the picture so quickly, maybe waiting and then going all out with 1440p surround frameless monitors might be a better option. It'll be expensive, yes, but the experience may be all the more immersive.
And if you expect to work on it, then buying it now might be a good solution, if productivity with one screen is an issue (it usually isn't). Also, once you go widescreen, you can't go back hahaha
So to finish off another massive forum post, I don't think right now you should go for the setup. You only have $400 to spend and those monitors will only be much slower in game (because you won't be able to purchase another graphics card), and you'll have the borders to worry about (I assume the monitors aren't borderless because its only $200). And then you run into the problem of whether you should replace your old monitor, because it has borders too.
I recommend when you have the cash, go all out with the best possible setup that you want. Then you don't have to worry about getting something 'better' while dealing with something 'sorta-almost there' for some time. Also, prices for monitors will drop, and maybe in a couple years you can get borderless 1440p Gsync 144Hz monitors cheap... who knows? And by then, single GPUs the cost of a 970 will be able to single-handedly power an entire setup like that or like the one you're planning easily (maybe).
