Get the VE248h. Its a bit cheaper and I have 2 of them in addition to my vg248qe
With sub $200 monitors you might as well save $60 total and put it towards the stand you want.
check on amazon there are a few options. Be aware that a lot of stands require you to drill a hole in your desk to ancor it.
https://linustechtips.com/topic/32568-triple-monitor-stand/#findComment-416440
I would go with the comparable ASUS IPS monitors instead and Ergotron always had nice very adjustable stands but their not cheap.
https://linustechtips.com/topic/32568-triple-monitor-stand/#findComment-418982
The xfx stand is a pretty good stand, I'm on my phone so I can't post a link, but Linus did an unboxing and it looks to be pretty good
Ps: speaking of monitor stands, are there any stands for 27-32inch monitors?
Yes I have  seen 2x1, 3x1, 2x2, and possibly even 3x2. Id have to look them up again though. From what I do remember is that they arnt very adjustable and they have a big plate that they advise you to bolt to your desk.
https://linustechtips.com/topic/32568-triple-monitor-stand/#findComment-420564
I've been looking for exactly the same stand.
I've seen this one but have found a lot of people saying that for 24" screens you can align them all flush with a decent curve towards you.
Seems to be a common problem with all the cheaper stands.
So much so think I am going to get 23" screens instead. LG 23EA63V
If you do get that stand, please update this post with feedback
https://linustechtips.com/topic/32568-triple-monitor-stand/#findComment-424801
Just setup 3x 24" screens with an XFX stand, it's a bit pricey but it's awesome. Very well made all metal construction. The base is massive and so stable even was able to attach all the monitors one by one without the whole thing tipping over. Also the brackets once attached to the monitors just click into the stand...
Lian Li PC-V359WRX Micro-ATX Case | Intel 5960X Extreme 3.00GHz | ASRock Fatal1ty X99M KILLER | Crucial 32 GB 2666 DDR4 | Thermaltake NiC C5 | EVGA Supernova 1200W P2 | 2x 240GB OCZ Radeon R7 | 2x 256 GB Samsung 840 Series Pro | 2 X 120GB Samsung 840 EVO | 6x NF-F12’s | Place Holder GPU R9 290X |
Links Current 5960X Old FX9590
https://linustechtips.com/topic/32568-triple-monitor-stand/#findComment-424846
Here is the place that has the multimonitor stands for larger than 23-24in monitors http://goo.gl/RdN5Y
https://linustechtips.com/topic/32568-triple-monitor-stand/#findComment-427146
