Posted July 4, 2013 So I just put my old gtx 560 se into my system along side my 7950. I did all the cracks but now the nvidea card is the main card and the 7950 is the secondary. Is there anyway to correct this.GPU Z says they both have PhysX now. The 560se is in the top pcie slot because the 7950 is a triple slot and only fits on the bottom slot. They both are x16 slots. Link to comment https://linustechtips.com/topic/32551-hybrid-physx-problem-nvidea-is-still-the-main-card/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 4, 2013 Go to nvidia contor panel and set physX to 560. Error 709: Walrus on the road! My build log: http://linustechtips.com/main/topic/131216-the-small-white-p-node-304-build http://linustechtips.com/main/topic/190057-build-the-large-p/ Link to comment https://linustechtips.com/topic/32551-hybrid-physx-problem-nvidea-is-still-the-main-card/#findComment-416136 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 4, 2013 I'm pretty sure you can change your primary output in the bios. Look for something like 'graphics adapter' or 'primary display'. Then do what M-ursu says and set the 560 as your physx card. Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks -CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD -Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A Link to comment https://linustechtips.com/topic/32551-hybrid-physx-problem-nvidea-is-still-the-main-card/#findComment-416150 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
