So the BEST OC I could get on it was 1100/1500 semi stable @ 1.3V.  Tested both bios's and my card has the 7970 PCB with dual 8 pin connectors.  Right now it;s at 1050/1450 because its the MOST stable.  Then I noticed my ASIC score was like 59.  Does this actually mean my card is THAT bad?  Often people RMA below 70.
Specs: Core I7-2600K @ 4.5GHz @ 1.35V, 4x4GB Corsair Vengeance Black 1600MHz CL9, Cooler Master Evo 212, MSI Z77 Mpower Motherboard, Sapphire Radeon HD 7950 Vapor-X @ 1000/1400, Cooler Master HAF 932 Blue Edition w/ 3 Cougar Hydraulic Bearing 120MM fans (2 up top 1 in the bottom) replaced side panel with a window, and rear fan with a Cougar Hydraulic Bearing 140MM, Cooler Master GX 650 80+ Bronze PSU, Samsung DVD-RW, Samsung 840 Pro 128GB SSD, Seagate 750GB SATA III 7200RPM
https://linustechtips.com/topic/32360-hd-7950-vapor-x-and-asic-quality/
I don't think you can RMA a card because it's a bad overclocker lol.
the higher the ASIC the less voltage you'll need to achieve higher clock speeds.
the lower the ASIC the more voltage.
typically people say that 60% and under means you need watercooling to achieve a good overclock.
it's the silicone lottery,you lost;sucks,but i happens to everyone eventually.
try playing again with the HD 9000 series.
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
I am gonna get 2x HD 7950's reference designs and block them both.
