Budget?
https://linustechtips.com/topic/32143-monitor-suggestions/#findComment-410581
The ASUS VS247H-P is an excellent choice. I myself use an ASUS VS239H-P, which is an e-IPS panel that I'd also recommend if you're not hardcore enough to need the 2ms response time of the VS247H-P.
Intel Core i7-5930K | Noctua NH-D15S | ASUS X99-M WS | 32GB (4 x 8GB) G.Skill Ripjaws V 2666MHz | MSI GeForce GTX 980 Ti Gaming 6G | Samsung 850 Pro 512GB | Seasonic 660XP2 | Phanteks Enthoo EVOLV
LG 34UM95-P w/ Ergotron MX  | O2/ODAC | Audioengine A5+ w/ AS8 | Sennheiser HD 598 | Ducky Shine 3 | Cooler Master Storm Spawn
https://linustechtips.com/topic/32143-monitor-suggestions/#findComment-411046
id grab a ASUS IPS that fits into your budget.
https://linustechtips.com/topic/32143-monitor-suggestions/#findComment-419156
