Where to put my radiator in Fractal Design Define R5
Solved by Heba1963,
Yeah, hopefully they installed the H100i correctly. Here's a guide to how it should be done: http://www.corsair.com/en/blog/2013/february/how-to-install-the-hydro-series-h100i-cpu-cooler
In this video, at around 2:00 you can see how the roof is. It will still be covered off with the H100i installed in the top.
Hi Shaqo_Wyn
I just returned today from the shop with my Be Quiet Silent 800 case after they moved the hardware over to it.
I cant say it sounds amazing, because there are no sound "extreme bad joke".
There is only a low whisper when I dont have headphones on and with headphones and gaming I cant here the computer.
So many thx for giving me the advice with this case.
Best wishes
Henrik/Denmark
