Need help in choosing a monitor for Auto Cad works (architectural to be specific.) :) and occasional gaming.
JER_RLA
Go to solution Solved by Glenwing,
thanks sir.. i don't know a lot of models that come in 16:10 ratio. anything specific i should look in to? :)
The two I mentioned are both 16:10 :P The U2412M has basically been replaced by the U2415.
any suggestions for a monitor ideal for cad and occasional gaming? Thanks in advance :D
exactly at that price point or less than $300..  :)
U2415 is my recommendation then :) The PA248Q is also a good option if you're really strapped for cash as it's slightly cheaper, but not by that much. The U2415 is a bit newer and I'd consider it to be the better monitor if you can stretch for it.
MechE here, I use Solidworks for a living
Anything 16:10. No other resolution aspect ratio is as good for CAD as that. 16:9 is too wide for the height, ultrawide is worse (unless you splitscreen), and pro engineering applications have very poor high dpi support since there is no benefit to the user.
Gaming-wise, I gamed throuhout undergrad and grad school on a 16:10 display just fine. It isn't an issue.
Also, if Autodesk is opengl, get a quadro/firepro card or build a separate engineering workstation (i7, lots of ram, workstation card). Huge difference if you intend to make money/get jobs using cad skills.
Dell 24" ultrasharps have the option. I don't know which all do, but tthe u2412 is 16:10.
oh i see.. good to know i was on the right track. haha. thanks again :D
thanks a lot! will definitely buy dell now. hahah!
