MSI Afterburner not saving settings.
Solved by Badger906,
if you're worried about having afterburner open for resource purposes it's already too late!!
just click apply and then click on a profile then save.
tick the box at the bottom that says run overclock at start up and then it runs in the back ground without you ever seeing it open.
BTSHalfLifeAndGmodFan2003 ·
Posted in Graphics Cards0 -
4
john b ·
Posted in Phones and Tablets3
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
