GTX 960 Review Roundup
BonSie
Think it's best to put the 960 reviews in a single topic instead of spamming the section with it.
If seen some of the reviews and it's a definite improvement in performance over the 760, but the price is too high since it struggles to beat the AMD 280 variants, especially considering there 2 years older.
Reviews:
Hardware.info
PCPer
HardwareCanucks(Strix)
Techspot(GW Phantom)
PCGamesHardware.de
Techreport
Guru3D (Strix SLI + MSI/GB&KFA2)
Techpowerup (EVGA + MSI&ASUS)
PCWorld
TomsHardware
Tell me if you find more
FX-8120 | ASUS Crosshair V Formula | G.Skill Sniper 8GB DDR3-1866 CL9 | Club3D Radeon R9 290 RoyalAce |Thermaltake Chaser MkIII | 128GB M4 Crucial + 2TB HDD storage | Cooler Master 850M | Scythe Mugen 3 | Corsair Strafe RGB | Logitech G500
unfortunately this launch does not help the PC gaming ecosystem.
i.e it does not help gamers with small budgets obtain access to better levels of visual fidelity and performance.
Cards like the 560ti or 7850 did that... which is what you want midrange hardware to do.
TL;DR - Bleh. Keep mentioning your silence and power consumption, but what gamers really want is POWA! It's not that other similar priced GPUs sounds like airplane anyway.
Laptop: Acer V3-772G  CPU: i5 4200M GPU: GT 750M SSD: Crucial MX100 256GB
DesktopCPU: R7 1700x GPU: RTX 2080 SSDSamsung 860 Evo 1TB
It's also why I still have a 560.
:ph34r:
I'll be sticking with my 760 for now.
Does anyone know if MFAA is Maxwell-exlusive? I assume so, but I'm not sure.
What's the point of this card ?
We had the GTX660/660Ti/670/680/770/760 all do the exact same thing.
And the R9-280X is the same price and has 3GB Vram.
And you can get 290s already for 280€.
RTX2070OC
Gonna save up a few more bucks for the 970
System Spec: H87 mobo from Zotac, I3 4130, 4GB ddr3 1600mhz Cas 11, WD green 2TB all in side of a Cooler Mater Elite 120
Here in Canada I can buy a 290 for less than a 960. Going to do exactly that
Intel 4670K /w TT water 2.0 performer, GTX 1070FE, Gigabyte Z87X-DH3, Corsair HX750, 16GB Mushkin 1333mhz, Fractal R4 Windowed, Varmilo mint TKL, Logitech m310, HP Pavilion 23bw, Logitech 2.1 Speakers
I'll stick with my 770 for another year or so, unless I can find one for about $150, then I'll SLI.
Case: Thermaltake Versa H35 | CPU: AMD Ryzen 7 1700x (@4.0Ghz) Cooling: Cooler Master MasterLiquid Lite 240 | MOBO: Gigabyte AB350M-DS3H | RAM: Corsair Vengeance Pro RGB 16GB (2x8GB) 3333Mhz | GPU: MSI ARMOR 8GB OC GTX 1070 | Storage: SAMSUNG 970 EVO 250GB, 1TB Seagate 2.5" 5400RPM | PSU: Corsair CX750M
I have a 660 still and was planning on upgrading to the 960, but on a university student budget (i.e virtually no money) this doesn't seem like a worthy upgrade, does it? Do I go the 280(x?) route or wait and see what happens? My 660 still runs most games at 1080 well. However, I have a 144hz monitor and need a gpu that can get me closer to that framerate. I wish Nvidia would help us midrange guys better :(
AMD will be releasing their GPU in March/April, might want to wait for those.
And they will probably lower the prices to get rid of their stock.
They are just sticking to this price point because of brand loyalty. Some people will go with this card no mater what AMD has to offer at the same price.
Ordered the 290 this morning for $289!
960s are $269-309 here.
290 will crush
