best monitor for $300?
ajhoranny89
Im planning to get a gaming monitor of @ $300 that can work really really good with 2 "evga 970 ftw" plz link your best recommendation for the $300. Ty
QNIX QX2710.
1440p, IPS, capable of 96Hz
"Rawr XD"
A good 144Hz 1080p 24" TN panel like the BenQ XL2420Z or XL2430T.
Bert & Ernie before squirting spermie.
Hi,
Go for ASUS VG248QE it is great for it's 144hz smoothness and is perfect for CS:GO due to it's high refresh rate.
It's also has 3D capable if you're into that sort of thing, your setup also won't have a problem with getting 144+ fps on CS:GO, which is fine for 144hz gaming, however I'm unsure of the other games, they shouldn't be a problem though.
http://www.amazon.com/VG248QE-24-inch-LED-lit-Monitor-response/dp/B00B2HH7G0/ref=sr_1_3?s=electronics&ie=UTF8&qid=1411587403&sr=1-3&keywords=120hz
