Is my power supply enough for this?
Solved by Excon,
What do you mean by it will still work? What's the benefit of getting a bigger power supply when exactly 430w is just about all I need? Is it going to blow up or something? Lol
Well if you overload the power supply it will automatically shutdown. Its not a bad thing if this happens. Just means you need a bigger PSU. The 280x has a 250w TDP, i3 is 80w, fans drives and everything else is 40w tops. So realistically you will be fine
