CPU-Fan is not spinning/ spinning
Solved by Onliner94,
Take the sticker on the fan off and lubricate inside there, I've had the same problem many times.
Maybe it helps... anyways I contacted Scythe and they'll send me a new fan in a couple of days... but till then I might try this out!
Edit: It's been quite some time but I guess it might be important to say, that I contacted Scythe and they have send me a new fan after I emailed them the bill from my rig where my cpu cooler was included! They didn't ask for anything more than my location ofc but the new fan came pretty fast and they didn't even want to know anything else! So great support from Scythe! And the old fan was just broke... don't know what exactly happened to him!
