usb over current statuc detected. Problem please help.
Solved by BroKenFingers,
there are lots of hits about the trouble you are having..you are not alone. Some say clean the crud ( favorite tech term ) from all the USB ports..others say it is a MB to case short..
.do you have a PS/2 KB to try ?
.there is a jumper for ..power to KB ..what ever that means..
Sorry this looks like one of those "try this and see what happens.."
Keep at it..have you tried with the OB GPU only..?
