water less water cooling?
Solved by WoodenMarker,
but then then air Will go though a rad and cool. So the air goes: block-fan-rad-fan -block
Granted it wouldn't be the most effective, but.
The point of the rad is to cool the (water, in this case air) to go back to the cpu. Fresh air would be cooler than recirculated air.
Again, the issue is that water is much better than air at transferring heat--it's the reason eggs are boiled in water instead of being put (shell and all) into an empty pot.
