water cooling vs air cooling
alvez
 Share
well ive recently bough an i5 4690k
im wondering if i should buy a water cooler or a air cooler ?
im looking for some suggestions, my budget is arround 75 € ;)
thanks! :D
| Case: Cooler Master Elite 371 | Cpu: i5 4690K @ 4.20 GHz | Cooler: Cooler Master Hyper 212 Evo | Motherboard: MSI Z97 Gaming 3 |
 | Gpu: Gigabyte G1 Gaming GTX 970 4GB GDDR5 | SSD: Crucial MX100 256 GB | HDD: Samsung 128GB Ram: Kingston 8GB DDR3 1333MHz |
| Screen: Benq XL2411Z | Mouse: Logitech G 403 | Mousepad: SteelSeries QcK+ NiP Edition | Keyboard: Steelseries 6GV2 | Headset: Kingston Hyper X Cloud |
how much will you be overclocking?
well a CLC is good if you consider it but I still go with noctua nh-d15 (I'm a D14 fan :D)
if you got the budget to blow I'd really say go on custom loop. not only do they keep the temp down (not lower than room temp) but it will make your slut look more sexy.
Live your life like a dream.
thanks! :D
noctua nh-d15
The blood on to your heart start pumping faster when you notice me.
But is ok.
Judge me for my nickname, my avatar and for the low amounts of posts I have. I will keep your heart beat raised.
Watercooling looks cleaner, air coolers are cheaper and stick out a lot.
I'd suggest going with watercooling if you plan to overclock, there are some great aios out there. (H100i, h110, etc..)
to be honest ill not overclock hugly just going to keep it like 4.1 or less, even 3.9 all the time (stock turbo)..
would you bother take a look at this post?
http://linustechtips.com/main/topic/235196-i5-4690k-temperature/#entry3222310
i really like the aspect of this one_! http://www.coolermaster.com/cooling/cpu-air-cooler/v8-gts/ i dont know if its good tho xD ty
your fine with air then
Well lets compare high end AIO's and high end Air coolers:
Performance: same
reliability: Air wins
noise: Air wins by a mile
cost: Air wins
Installation: AIO wins
looks: Personal
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
noctua nh-d15
this looks similar to that one, i really like tha aspect
 http://www.coolermas...-cooler/v8-gts/ is it good ?
Preference? I like the H110. I like its aesthetic. It's complete overkill -- the voltage I would need for temps to be an issue would degrade my CPU in itself, I like the fact that its fans attach to the case and dump the heat straight out, and I'm more comfortable with not hanging a massive lump of metal from a thin sheet of fibreglass. To get the same performance from an air cooler you're limited to the NH-D15, whose overhang gives it compatibility issues with motherboards whose first PCI slot is their 16x PCI-E that you need for a GPU.
Oh. Well in that case grab the CM Hyper 212 EVO.
Performance: same
cost: Air wins
looks: Personal
any suggestons on air ones :P ?
ive really been looking to this one! :)
but well i dont know in the future u know..i like this one: is it good! :D ?
http://www.chiptec.net/componentes-para-computadores/cooling/coolers-para-cpu/cooler-master-v8-gts.html
I wouldn't recommend the V8 tbh, it performs ok, but its actually really loud for an air cooler and I think its ugly as fu.
This is the list of high end ones I recommend:
NH-D15
NH-D14
NH-U14s
cryorig r1
phanteks ph-tc14pe
Be quiet! dark rock pro 3
Noctua NH-D15 = Top Dog of Air Coolers
NZXT Kraken X61 = Top Dog of AIOs (I know the H220X exists, but that one is special)
Custom Loop = Best of All, but will also rape your dear wallet.
Depends on how much you're going to overclock, if it's mild, just get something like an NH-D14 or Dark Rock Pro 3. If you're going to overclock to high hell, I would get an AIO, NH-D15 or if money allows, a Custom Loop.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
that engine looking one hahaha I have that one on my htpc rig (old one and slapped it in) made it look good.
well I for one made a custom loop on my gaming (i3) rig just for the looks. if you really like the sexy look of custom look go ahead :)
no... the v8 looks good but is just bad, noctua nh-d15 is the best cpu cooler out there!
But is ok.
ill not overclock that much you know ;) i just play counter strike global offensive, i just want it to be safe and cool (temperature)
seems that everyone recommends: http://www.coolermaster.com/cooling/cpu-air-cooler/hyper-212-evo/
seems that it does have a good image for the costumers
thanks! :D
skip to 4:35
But is ok.
alright, but the noctua is more like for high OC right?
if i plan to keep it at 3,9 ghz just  need to buy this one ? http://www.coolermaster.com/cooling/cpu-air-cooler/hyper-212-evo/
not rly. the cooler it run the better with time. just buy the nh-d15, spend all the money xD and yes the 212 evo is good but outdated >.> I would buy nh-d15
But is ok.
 Share
