Water cooling problem
Xaryon
 Share
Hi,
I bought a Cooler Master Seidon 120V for my i5-3570k. It work kinda quiet (but their fan is still a little too loud) and I started to get strange temp readings. When I installed it I got some nice 29 degrees Celcius on my CPU, with like 45 under load. Recently I get 45 degrees on IDLE. I changed the thermal compound to Arctic cooling and I still get high numbers on IDLE.
"xCube" -> CPU: Ryzen 7 2700x | RAM: Palit 32 (2x 16GB) DDR4 CL16 | MOBO: Biostar x370GTN ver. 5.x | GPU: Gigabyte nVidia GeForce GTX 1060 Aorus Extreme 6GB | PSU: Corsair VS Series 650W | Storage: SSD: ADATA SX8200PNP 512GB NVMe & Kingston SA400 960GB / HDD: HGST 4TB & WD Black 2TB | OS: Windows 10 Pro | Cooling: AMD Wraith Prism | Case: Corsair Carbide Series 240 Air
Maybe check your cpu load, programs running to make sure that its doing nothing first? Then after that you've done that perhaps you could check if the pump etc is working correctly, check if the tubes are bent or something that might restrict the cooling loop? Or perhaps you've changed some settings and now the pump is running really slow
Desktop: i7-6700K / Asus Z170 S / H100i V2 / LPX 2400Mhz 16GB / 960 EVO 250GB / 2x 860 EVO 500GB / RM750i  / NZXT H440 XB271H + Z22n Monitors
Laptop: Thinkpad T450s / i7-5600U / 12GB / 860 EVO 500GB
 Share
