Help optimising airflow / fan placement on a H440
Superfreeky
Recently installed a kraken g10 with a h55 onto my graphics card and it got me thinking about the best way to manage airflow as I have various fans about that I feel could be better utilised. I have 3 140mm SP fans, 1 140mm FN fan, 3 120mm FN fans and 1 120mm SP fan. My case has mounts for either 3 120mm or 2 140mm on the front and top and a mount for a 120mm or 140mm on the back. The thing I'm most struggling with is what fan to use on the rad and where to place it. Side note, I'm also using a grid + and I have my fans running at 40% most the time.
post-150786-0-83875900-1413602902_thumb.
post-150786-0-46865100-1413602928_thumb.
post-150786-0-26810300-1413602935_thumb.
post-150786-0-79852000-1413602942_thumb.
Put the static pressure fans on the rad
err.....fan, since you only have one
CPU: AMD Ryzen 7 3800X GPU: ASUS Strix Radeon R7 5700 XT OC Edition Motherboard: ASUS Crosshair VIII Hero RAM: G.Skill Trident Z DDR4-3200 CL14 SSD: 2x Samsung 970 EVO Plus 1TB PSU: Corsair AX860 Cooling: NZXT Kraken X72 Case: Corsair Crystal Series 570X Mirror Black Display: BenQ XL2420Z  Keyboard: Corsair K95 RGB Cherry MX Blue Mouse: Logitech G502 Proteus Spectrum Audio: Logitech G633 Artemis Spectrum
place the rad at the rear and attach your sp 120 to it.
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
This
make use of all the fan options of your case. put the rad in front to and orient the fan as intake. You should put static pressure optimized fans on front and on top(120mm) then an airflow optimized fan on the rear(140mm).
My Current PC Codename: Scrapper
Intel i5-3570 | Some LGA 1155 MOBO Some Generic DDR3 8GB 1600Mhz | PowerColor RX 560 2GB | Recycled HP Case Crucial MX100 128GB 1TB WD Blue 7200RPM | Some Generic 500w PSU | Intel Stock Cooler
exhaust>intake. Good luck cleaning the rad if you orientate it as intake. I would only recommend exhaust (even tho your tempts wouldnt be the coolest but it'll still be cool)
I wouldn't mind cleaning the rad. Besides, it won't be that bad since you have a filter at the front.
hmm it depends on OP then @Superfreeky
