4790K 3dmark 13 Fire Strike - too low physic score? Turbo not enabled?
sew999
 Share
Hello. I just test my new 4790K. But i think my 3dmark 13 Fire Strike physic score is too low. I get 11863 points.On review sites there are much higher scores for that cpu like 12300 points in that test.
Can somebody confirm that is ok or no;? Or maybe i dont have Turbo enabled to gain 4,4ghz? I must something change in BIOS then? I have all settings in bios on default.
you are aware that 12300 is only 103% of 11863? so you are within 3% difference...absolutely fine by me.
Motherboard and/or RAM speed will give that kind of performance difference and it's absolutely normal.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 2 VR
 Share
