ZOTAC GTX 970 AMP! Omega and AMP! Extreme plus a GTX 980 AMP! Extreme Giveaway!
The Zotac GTX 980 AMP look very nice indeed. With the quiet coolers and the beastly performance!
Note: In Denmark it's pretty easy to buy the Zotac gtx 980 AMP... +100 in stock ;D
Whaat??????!!!!!! Only red and green colors available. Why can't they just do RGB lighting to everything. Or atleast Blue so it would fit my case.  :P
I always liked the Zotac styling on cards, the old orange look worked well with my system til I went to water.
A shame they are so hard\impossible to buy in Australia.
With these being custom PCB's will their be custom waterblocks?
I'm thinking if I should upgrade my 280x for a gtx980.... but I'll wait for witcher 3 to be sure if I upgrade or not :D
I'm pretty surpised, how the new zotac editions look like.
I think they look much better then the old ones...
Great looking cards!
Thanks Zotac & Linus for this giveaway :) Good luck everyone
those are some good looking cards, the thicker backplate wouldnt be much of a problem if its the only card you are running anyways
such cool, much wow!
CPU i7-930 @ 4GHz Mobo Asus P6X58D-E GPU Gigabyte 970 G1 RAM Patriot Division 4 Viper Extreme 8GB HDD Western Digital 1TB SSD Samsung 840 pro 128GB PSU Corsair TX 750w Cooling Corsair H100i Os Win 10 Pro Monitor AOC G2460PG
Trying my luck at this. Either way, I been watching Linus for many years now so your post count logic is ass!
I like Zotac's new coolers, they both look awesome. I woudl be so happy with any of these new 900 series vgas so thanks Linus and Zotac for the chance!
Guest
