Does the 2 way EVGA Sli Bridge Light up with the gtx 970?
CaptainKlark
 Share
Go to solution Solved by AlwaysFSX,
Yeah it should. I think the led works that if it receives power then it lights up.
Hi, I was wondering if anyone had experience with this sli bridge and specifically if it was able to light up with the MSI Twin Frozr gtx 970.
I am aware that the description only says it works with the titan and the 780, plus some 770s, but I figured it just hadn't been updated with the new cards.
It will light up even if just plugged into a single card.
Tell my tale to those who ask. Tell it truly; the ill deeds along with the good, and let me be judged accordingly.
Okay thanks!
  • 1 month later...
Sorry this is a little late but this is incorrect.
"The Pro SLI bridges will provide SLI functionality with all 900 series cards, but will only light up with all GTX 980 graphics cards. The Pro SLI bridges will function but NOT light up with any model of GTX 970 graphics card."
http://www.evga.com/support/faq/?f=59532
Current Rig
AMD Ryzen 5900X - Asus ROG Strix X570-E Gaming WiFi 2 - 32 GB GSkill TridentZ RGB
GeForce RTX 3080 - WD Black SN850 1TB  - Lian Li O11 Dynamic XL
 Share
