Monitor: Out of range
Hatsune Miku 「 」
 Share
Go to solution Solved by Hatsune Miku 「 」,
Nevermind. Plugging it into my TV and putting it back into my monitor worked.
I restarted my computer and it started up and now it keeps displaying out of range when ever I start it up. I haven't changed the resolution or any setting at reboot. I'm running Windows 10 Technical Preview on RAID 0,  using an R7 260x gpu on a 1400 x 900 monitor  using vga to dvi-i adapter.
"Instinct or Rationality; Which will you choose? Enchanted by a superiority complex"
"what you do in spite of internet speed is inspiring. :3" From Cae - 2015
 Share
