Best sub 45 euro air cooler?
H4X3R
Go to solution Solved by Archangel1994,
I originally wanted to buy the 612 v2 but then it ran out of stock.
Any good alternatives (PS, the 612 v2 was the best for the price).
Do not suggest the 212 evo, i'll need a good cooler for a stable 4 - 4.2ghz and sub 65*C on a 5820K.
Samung Tab S 8.4
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
2011-3 compatible? I'll search for a review myself.
It is 2011-3 compatible yes
Cool. Just look at 2 reviews, seems to be an awesome cooler. I'll be getting the pcgh edition as that adds a 2nd fan for just 3 euros ($5) more.
link: https://geizhals.at/scythe-mugen-4-pcgh-edition-scmg-4pcgh-a999348.html
Marked as solved.
You are very much welcome.
Just a sec, what about the mugen max?
I just watched a video:
(in german)
Would it fit into an x99 ud5 mobo?
Would it interfere with the 1st pci e gen 3 slot?
Samung Tab S 8.4
