Help pleasee ! gtx 970 vs r9 290x vs 780 ti
EzioSan
 Share
so my problem is:
Asus gtx 970 : 350€
Msi gtx 970 : 350€
Saphire Radeon r9 290x tri x oc : 325€
Asus gtx 780 ti  : 370€
i cant choose which one...gtx 970 are quiet and powerful , but the others are so damn cheap and powerful too
R9 290X Tri-X (from a Ti owner so don't call me a fan boy)
Intel Core i5 4690K @ 4.2Ghz | Evga GTX 780 Ti SC ACX with backplate | MSI Gaming 9 AC | 8GB (2x4) Corsair Vengeance Pro Silver 2400 MHz | Corsair H105 128GB Crucial MX100 | Toshiba 2TB | Evga 750G2 | Corsair Obsidian 750d | Be Quiet Silent Wings 2 PWM (3x140mm & 3x120mm)
Go with the 780 ti it's only another 20 euros, and I doubt that is gonna make a big difference on someone buying such a high end card.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
I'd get the 970 solely for the 4GB VRAM and better NVENC chip.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
780 ti will give you the best performance
A 970 is in the middle of a 770 and a 780 but it can OC like crazy
What.  A 970 beats a 780 hands down in almost every scenario, and is as fast as a stock 980 when overclocked.
Guys have you looked at the prices? The 780ti is a nobrainer for only 20€ extra.
Why the 780Ti when I can get a cheaper 970 and OC it and perform the same while having the latest tech and more VRAM?
I'd go with the new 970, and think if I want MSI or Asus? ..too bad you can't get Sapphire 970's!  :ph34r:
You'll have to get that 970 to 1800 mhz or so to match a 780ti.
What.  At 1500MHz it's already beating the 780Ti.
No it's not. A 1520 mhz it's still roughly 10% slower than the 780ti.
go with 970 and overclock but if you dont care about the features and additional ram go with 780ti  :D
*780ti then
lol
780 ti, or if you arer on a budget that 290x is a GREAT deal.
† TTCF Member † Jesus loves you! Have a good day and stay techie!
 Share
