Guys I want to be able to use the EXACT fittings that this system used for the main 5 block configuration, around the cpu, motherboard, and memory water blocks. I would love to know what kind of extension fittings hes using as the are the only ones i cant figure out.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
they are bitpower, i just need to know how long i need the extensions.to be figured out.
My bad. I'm a little confused. You want to know what extension lengths you need?
so i would just need to get the male to female versions of thouse? how many would i need of each?
Male to female yes. What I would do is get all your stuff, buy one of each and then test fit it. Best way to make sure. He is just using a lot of right angles there. If you don't want to wait, you could just count in the video.
