I need help with my gtx 780ti
 Share
I recently just built my new pc with a gtx 780ti the only problem is I get horrible frame drops in games for example in cs go 250 fps to about 60 fps here are my specs:
Amd 9590 stock clock
Gigabyte gtx780ti oc edition
16 gb ram
Asrock 990fx extreme 3
Well do you have a decent cooler on the 9590? That thing will throttle quite hard unless you have a pretty good cooler like the Noctua NH-D15.
Also check the temps of your GPU and CPU using something like HWmonitor, HWiNFO or Speccy or MSI afterburner
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
what are your cpu and gpu temps? and like what is said above, your CPU might be throttling due to not having a decent cooler on it.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
And what is your power suply the 9590 is a hungry bugger as is the 780ti
ICT professional, Addicted to PC
The 780ti is not a power hungry bugger. The 9590 is
still doesn't answer the question whats your Power Supply
OK that PSU is fine, next what are your games running off? IE where are they installed, have you got Geforce Experience installed to optimize your games?
 Share
