Bottleneck Issue i guess?
levsingh
 Share
Hey guys i think i am having a ram bottleneck in my system.
my system specs:-
i7 4770k
ddr3 2400mhz 8gb single channel
2x r9 290x reference in crossfire (they are not causing the throttling because they are under 94C )
500gb WD blue hard disk with 16M Cache
so i setup msi afterburner and HWINFO and put all the usage info there (check the attached file for details) and lauched middle earth shadow of mordor and found that gpus are fine, cpu usage fine(row 5), row 6 is the cpu temp,
virtual memory and physical memory loads look pretty much maxed out, could someone please explain me whats the difference between these two?
and the last one is the D3D usage of the main GPU in the crossfire setup.
so guys help :P
post-55381-0-50890900-1412449557_thumb.j
You could see if memtest picks anything up.
can you give me the link to the software? thankyou
nah man no errors and suggestions?
what exactly is wring with it? I can't really read that, is it running at a slower speed?
Try disabling low power states on both your CPU and GPU and try again...
The one on the CPU can be disabled in the BIOS (at least that's how it works for my system)... Use Afterburner to disble the one on the GPU...
Edit: Took a good look at the screencap, GPU2 is underutilized (I think)...
 Share
