Need some help with my first build
Solved by WoodenMarker,
Went a bit over the budget but you said you wanted optimal performance: http://au.pcpartpicker.com/p/12Uc4 $1573 AUS
The Xeon is basically a 3770 but lower 0.1ghz lower clock/0.2 turbo clock speed. The thread should help and it's fast enough not to in all practicality bottleneck anything.
The B75 has front usb 3.0 headers as well as 4 ram slots. It'll do anything an atx board needs.
16 gigs of 1600 memory should give room for editing/multitasking.
Samsung 840--fast ssd, good price. Awesome sauce.
Seagate Barracuda 2TB for storage.
GTX 780--gaming/editing--check.
Antex one is a slightly cheaper, and simple case with what you need. Change the case if you prefer. Looks are all up to you.
Antec 620w will provide plenty of power.
