Is heat bad for hard drives?
theloveablemoose
 Share
Go to solution Solved by LemonSpice,
Got a front fan on my case that i thought may be a better addition to my hyper 212 so yeah shall i move it or no?
heat does kill them but not cery fast but then again the spinning fan might cause more vibrations than the heat so it might do nothig to prolong if not hurt its lifespan
it does matter but only at extremely high temps
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
Heat will only hit a HDD hard if it's some really high temps. It's still best to try and keep heat away from any PC component...that's common sense.
There is a limit to how hot your hard drive should be getting. Mine have all been under 40C and I've beaten the shit out of them and they last quite a while.
Main rig on profile
Zephyrus - Windows 7 side rig
Intel Core i7 4820K, 1x8GB ADATA XPG V1.0 (1600MHz CL9), Asus Sabertooth X79, 240GB Kingston UV400, 1TB Toshiba 2.5", EVGA GTX 960 SC, Enthoo Pro, Corsair CX750M, Windows 7 Ultimate 64-bit
Mac Mini (Late 2014)
Intel Core i5 4278U, 8GB RAM, 250GB Samsung 840 EVO, macOS Monterey, Logitech G305 K/DA, Logitech MX Keys for Mac, ViewSonic VX2748 (last two shared with main PC)
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X 1TB (technically retired now), Xbox Series X, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 2TB, Nintendo Switch OLED
Heat won't do much to your hard drives until it reaches around 50C, at which point it isn't doing it any good at all. If the front of the case has ventilation, then it should be fine.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
Having a front fan on your case will do better for your HDD then adding a second fan to a Hyper 212 will do for CPU temps. You'll only get around a 2-3 degree improvement, since the tower isn't that huge
"Rawr XD"
Since it hasn't been mentioned yet, here's a study Google did
a few years ago; temperatures well into the 40 C range are not
an issue, and if you check out HDD manufacturers' spec sheets,
most HDDs are spec'd up to ~55 C or so.
https://research.google.com/archive/disk_failures.pdf
The most prevalent killer of HDDs, once they've survived an
initial timeframe, is simply old age according to that study.
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
 Share
