Case fans, and keeping system quiet
racerking
 Share
HI,
I'm looking to upgrade my case and fan cooling for my rig.
Setup:
Fractal Design Define R4
Cooler Master RS 850W Power
Asus Maximus Extreme 4
Intel i7-4770k
Gefore GTX Titan
The CPU temp is around 33c and the cpu fans are at 2331 rpm controlled through the AI Suite application.
I'd like to get higher quality internal chassis fans to reduce noise.
Thank you
Anthony
nb4 noctua
Rosewill Hyperborea/Akasa Apache fans are inexpensive and very good.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
Aerocool ds fans or ap123
 Share
