Cooler for Corsair Carbide Spec-03
Fleutius
 Share
Hello there.
I am putting together a pc with a LGA1150 socket MB with a i7 4790K processor.
It is going into a Corsair Carbide Spec-03 case, but I am having issues finding the  right cooler for it.
According to Corsairs website, the maximium cooler height is 157mm. wich rules out Noctua NH-U14s and NH-U12s at least as far as I have been able to see.
after looking things over, i ended up looking at a Noctua NH-C14, but I fear it to be less than ideal.
Do you have any tips for this situation.
(And before anyone says it, the Case is allready bought ;) )
 Share
