Searching for my next mouse (thoughts?)
tl;dr. I hate background services, icons and restarting my computer.
I have the logitech software on my PC, and it doesn't run in the background or have to be open. once you've downloaded it, set it up with your mouse and sorted anything you want on it (mouse button profiles, LEDs etc.) you can just close the software and it will maintain what you have set, without the need for constant updates. really easy to use IMO. Something like the corsair M45 would fit your needs, although I did see what you said about the aesthetic. Or the logitech G300 would be a decent choice, with 2500dpi max, but probably a few too many buttons for you. The steelseries senei/sensei raw is a cracking mouse, with everything you'd probably need, but you would probably have to install the steelseries engine software. Have you had a look at the CM storm recon? no idea on how good it is, but it's a bit of a left field choice.
