Need Help ! This is my first build in my entire life
calebe
Hi guys im planning to build my first gaming PC this are the specs
1. Budget & Location
My budget is around $1500 USD (i live in singapore so its around 1900 SGD )
2. Aim
Gaming just Gaming ... such as Battlefield Series and many more
3. Monitors
Plan on having two monitors but not more than that (FHD Monitors i already have it)
4. Peripherals
I do not need to purchase peripherals such as keyboards and mice as well as monitors ect
5. Why are you upgrading?
Im using and 5 year old computer and i hardly can play game with medium graphics
  • CPU: Intel Core i7-4790 3.6GHz Quad-Core Processor
  • CPU Cooler: Corsair H60 54.0 CFM Liquid CPU Cooler
  • Motherboard: Asus H97-PLUS ATX LGA1150 Motherboard
  • Memory: Corsair Vengeance Pro 8GB (2 x 4GB) DDR3-1600 Memory
  • Storage: Samsung 840 Pro Series 128GB 2.5" Solid State Drive
  •                  : Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive
  • Video Card: Asus Radeon R9 290 4GB DirectCU II Video Card
  • Power Supply: Corsair RM 650W 80+ Gold Certified Fully-Modular ATX Power Supply
 Case .... haven decide on it yet ...
PS. first time posting , bad English sorry for the inconvenience caused and totally pc noob :wacko:
Thanks in advance
Regards
use the quote button if you want my help
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($239.99 @ Amazon)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($99.99 @ Newegg)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($139.99 @ Newegg)
Memory: Kingston Fury Black Series 8GB (2 x 4GB) DDR3-1600 Memory  ($79.98 @ OutletPC)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive  ($138.23 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($54.99 @ Newegg)
Video Card: Gigabyte Radeon R9 290 4GB WINDFORCE Video Card (2-Way CrossFire)  ($319.99 @ Newegg)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($99.99 @ Newegg)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($86.66 @ Newegg)
Total: $1563.80
Specs
Total: $1563.80
only thing I would change about that, is maybe get a air cpu cooler such as be quiet shadow rock 3 because then you would have to remove the top two sound isolation foam for a liquid cooler which wouldn't be worth it just to say you have liquid cooling, but thats my opinion. Also air coolers are way quieter by like 10dbA
"to each their own"
Specs
Total: $1563.80
Hi thank you for your time for helping : sorry for this noob question is the 2-way CrossFire a need ? or a must  :unsure:
by nooooooo means is it a need however its a nice thing to have to be able to push them frames :D but if you want to save money you can get a single one
Specs
Man put this in Build Planning next time. It seems more appropriate there.
To alter SAV1OUR's build: go with G.SKILL's TridentX 8gb 1866mhzCL8/2133mhx CL9 RAM.
Two monitor's? K. But I find that weird. Usually I would reccomend a GTX series card, but to push more pixel's I would reccomend sli/crossfire. Maybe 2 GTX 770's/R9 290's will do the trick?
Storage: I have heard a lot of bad reviews on Seagate, but I can't validate their quality/dependabilty. But I can be confident in going with Western Digital Caviar Black.
Case: Just make sure it has good airflow. And get some fans in there too.
Those are my two cents, take it or leave it. Yes they are biased somewhat, they are opinions, but I don't just make things up out of the blue. I would say the same to a friend  ^_^
CPU: i7-4790k @4.8gHz  MOBO: Asus Maximus VII Hero GPU: EVGA GTX 980 SC ACX RAM: 8GB g.skill 2400mHz CL9 STORAGE: 240GB Intel 730 and 1TB WD Black PSU: Corsair AX760 COOLER: Corsair H110 CASE: Corsair 750D
