Wireless Mouse - Best Battery Life?
1 hour ago, Knight77 said:
I’ve got a G903 LightSpeed that needs replacing & wanted to ask,
Which Wireless Mouse has the best battery life?
There are 100's of wireless mice out there, search for one that suits your needs. Personally I use a G Pro and I need to charge it once every two weeks.
Look for mice with 500mAh and above battery capacity as they will tend to last longer. Also the higher the polling rate in use the larger the battery draw.
  • AMD Ryzen 7 5700X Undervolted  with PBO+Eco Mode
  • B550 Aorus Elite V2 Rev1.2
  • G.Skill TridentZ Neo 3600Mhz CL16 32gb (16gb x2)
  • MSI Mech 2X RX6600 8GB GDDR6
  • Deepcool AK620 WH
  • Deepcool CG580 WH
  • WD SN770 500gb + WD Blue 1tb HDD + Sn550 1Tb + MX500 1Tb
  • Antec EAG Pro 750 80+G
  • Benq Mobiuz EX2510 144Hz
Did you find the battery life of the G903 lacking? I have the G703 and it lasts days on a single charge. When travelling I try to top it up before I go and I usually don't need to again for the length of a trip.
No, its great, so looking for something with just as much if not more.
How about another G903? I've only really used the G703 so don't know if a lower model would be of interest at all. If you're looking for other general options, will have to leave that to others.
I'd get similar mouse I guess with comparable battery life. If you care mainly for battery there are those with replaceable ones and can also use BT as option over 2.4GHz too, so super long battery. But not like general mice need charging as a phone. Even smaller battery and higher polling rate. Yeah they drain faster but you switch when needed.
It has bugs now that the RGB keeps turning on even though I'm using On Baord Profile with all profiles having RGB Off.
Kinda annoying.
Kinda annoying.
G603. Uses AA batteries. Easy to replace. I use a rotating set of eneloops. They last forever on a charge.
