Z490I AORUS ULTRA Help
Go to solution Solved by QuinnKC,
5 hours ago, -rascal- said:
How many long beeps? How long are the pauses in between the beeps?
There are beep codes...like morse code.
https://www.computerhope.com/beep.htm#ami
https://blog.theretroweb.com/2024/01/20/amibios-beep-and-post-codes-list/
I figured it out. It was some weird interaction with clearing CMOS and the SDD i had in. For some reason after I took the drive out it booted to a screen saying like BIOS setting have changed would you like to load defaults". After that it started booting into BIOS without a problem.
Issue :  Not posting and can't tell if this motherboard has any way to tell me where its at in boot up.
Fans are spinning, GPU has power, BIOS Q-Flashed to F23. I'm kind of at a loss so any help would be appreciated.
Motherboard: Z490I AORUS ULTRA
CPU: i5-10400
Ram: 64gb Crucial DDR4 Pro
GPU: Arc B580
https://linustechtips.com/topic/1616094-z490i-aorus-ultra-help/
CPU: i5-10400
GPU: Arc B580
What is the exact memory kit that you have?
What SSD / HDD are you using?
Since the motherboard has no Debug LEDs, you'll need to purchase a motherboard speaker, plug it into the header, and listen to the BIOS beep codes.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1616094-z490i-aorus-ultra-help/#findComment-16754975
Put the speaker on it just keeps doing long beeps without any significant pauses
https://linustechtips.com/topic/1616094-z490i-aorus-ultra-help/#findComment-16755457
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/1616094-z490i-aorus-ultra-help/#findComment-16755968
https://linustechtips.com/topic/1616094-z490i-aorus-ultra-help/#findComment-16756189
