1.5 Gig Telus Connection looking for a switch
Solved by johnt,
Personal opinions: Go with 2.5 unless you have a direct need for 10 Gbps. The switches are dramatically more expensive, run hotter, and will be outdated when you finally upgrade your devices to match.
I would not hesitate to buy a used switch if you can find a reputable seller. You can probably find a good discount on Amazon for used products. They are pretty simple devices overall. But with Amazon Prime coming up in a week or so, you can probably find a great discount on a new one. Amazon has a lot of cheaper products. I got one from BrosTrend and it was functional while I had it. Well made with metal. Can't really tell about longevity. I switched to Unifi altogether for different reasons and got rid of it.
