Hi all,
I currently am using a pair of Steelseries Arctis 5 headphones that have a 3.5mm audio passthrough on the headset.  This allows me to plug into my Xbox controller and get sound from my Xbox as well as have the headset itself plugged into my PC.  This setup allows me to get audio from both my PC and my Xbox at the same time.  I do this so I can watch videos, use discord, etc on PC while playing with friends on Xbox.  The mic just went out in my headset, and I was looking for a new one, just to find out they discontinued this headset.  Are there any other options out there that would have the same feature of the audio passthrough?  I'm aware there are some wireless options, but I prefer wired as I never have to keep the headset charged.
https://linustechtips.com/topic/1615996-dual-input-pc-headphones/
This is actually news to me, sounds like an awesome feature.
I have to ask.... why not buy a desktop mic and stick with the headset?
Open-Back -HiFiman Edition XS - AudioTechnica ATH-R70x Refine - Sennheiser 6xx - Focal Elex - Phillips Fidelio X3 - Harmonicdyne Zeus -  Beyerdynamic DT1990 - *HiFi-man HE400i (2017) - *Phillips shp9500 - *SoundMAGIC HP200
Semi-Open - Beyerdynamic DT880-600 - Fostex T50RP - *AKG K240 studio
Closed-Back - Rode NTH-100m - Meze 99 Neo - AKG K361-BT - Blue Microphones Lola - *Beyerdynamic DT770-80 - *Meze 99 Noir - *Blon BL-B60 *Hifiman R7dx
On-Ear - Koss KPH30iCL Grado - Koss KPH30iCL Yaxi - Koss KPH40 Yaxi
IEM - Tin HiFi T2 - MoonDrop Quarks - Tangzu Wan'er S.G - Moondrop Chu - QKZ x HBB - 7HZ Salnotes Zero
Headset *Turtle Beach Stealth 700 V2 + xbox adapter - *Sennheiser Game One - *Razer Kraken Pro V2
DAC S.M.S.L SU-9
Class-D dac/amp Topping DX7 - Schiit Fulla E - Fosi Q4 - *Sybasonic SD-DAC63116
Class-D amp Topping A70
Class-A amp Emotiva A-100 - Xduoo MT-602 (hybrid tube)
Pure Tube amp Darkvoice 336SE - Little dot MKII - Nobsound Little Bear P7
Audio Interface Rode AI-1
Portable Amp Xduoo XP2-pro - *Truthear SHIO - *Fiio BTR3K BTR3Kpro
Mic Rode NT1 - *Antlion Mod Mic - *Neego Boom Mic - *Vmoda Boom Mic
Pads ZMF - Dekoni - Brainwavz - Shure - Yaxi - Grado - Wicked Cushions
Cables Hart Audio Cables - Periapt Audio Cables
Speakers Kef Q950 - Micca RB42 - Jamo S803 - Crown XLi1500 (power amp class A)
*given as gift or out of commission
Just now, Trey924 said:
Correct, with one reaponse, I was seeing if anyone else had a better solution
Also it didn’t completely offer a solution. The headset I use is a usb headset that plugs into my pc. And the 3.5mm jack is just a pass through on the headset. The headset itself isn’t a 3.5 mm jack
That is honestly the easiest solution to the mic issue but I just don’t like the thought of it personally.  If push comes to shove I can but That’s just me being difficult.
