Budget (including currency): $1000
Country: USA
Games, programs or workloads that it will be used for: Modded Minecraft, Max Graphics Single Player Games, looking for higher frames with high graphics
CPU: Intel Core i7-11700K 3.6 GHz 8-Core Processor  ($349.00 @ Amazon)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($34.90 @ Amazon)
Motherboard: MSI MAG Z590 TOMAHAWK WIFI ATX LGA1200 Motherboard
Memory: Corsair Vengeance RGB Pro 16 GB (4 x 8 GB) DDR4-3200 CL16 Memory  ($64.98 @ Amazon)
Storage: Crucial P5 Plus 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($199.99 @ Amazon)
Video Card: NVIDIA Founders Edition GeForce RTX 3060 Ti 8 GB Video Card  ($506.46 @ Amazon)
Case: Corsair 4000D Airflow ATX Mid Tower Case  ($94.99 @ Best Buy - OOS)
Power Supply: EVGA SuperNOVA 850 GT 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($123.20 @ Amazon)
wondering what a decent jump would be for my gpu. any help is appreciated, thanks! 💙
Country: USA
A 9070 XT would be an incredible jump in performance over your 3060 Ti.
What resolution are you playing at?
Do you prefer Nvidia GPU's or are you open to AMD?
Im open to both really. I play most games at 1440p so a 9070 XT would be a nice jump. Any other gpus that you would recommend?
Country: USA
AMD Radeon RX 9070XT. If your applications don't play well with AMD's drivers, then the Nvidia RTX 5070ti.
As you can see by the chart above, its an 18 game average at 1440p with high or ultra settings on each game tested.
The 9070 XT and 5070 Ti are both within your budget, they are around 800-880 dollars.
The 5070Ti will have better support like DLSS and RayTracing, this might matter quite a bit for your single player games to really push the graphical fidelity and framerate.
Here is a 6 game average at 1440p with RayTracing.
RTX 5070ti and RX 9070XT
