Help Red CPU light on motherboard
Go to solution Solved by DoctorNick,
3 minutes ago, javinator said:
thank you so much, but also new issue. red light on VGA now
Shut down PSU, make sure everything is well connected. GPU should work.
Make sure its not just some startup check. Its normal for all debug LED's to lightup when turning on the motherboard. Will go away after booting to OS (windows) You'll notice this after installing windows. Do you follow?
i have a gigabyte b650 aorus elite ax atx am5 motherboard, ryzen 7 7800x3d in a montech king 95 pro case and nvidia 4080 super.  I had an msi motherboard previously that was flashing red cpu and yellow dram and i couldnt fix that with many different solutions, so i purchased a different motherboard.  again, having issues with the new motherboard.  this time only the cpu is red on the motherboard  when i turn on the power, everything in the case seems to turn on, but the monitor stays blank.  image.thumb.jpg.33da58e4e97f087047f6b36e81a3400e.jpgplease help
https://linustechtips.com/topic/1615975-help-red-cpu-light-on-motherboard/
14 minutes ago, javinator said:
i have a gigabyte b650 aorus elite ax atx am5 motherboard, ryzen 7 7800x3d in a montech king 95 pro case and nvidia 4080 super.  I had an msi motherboard previously that was flashing red cpu and yellow dram and i couldnt fix that with many different solutions, so i purchased a different motherboard.  again, having issues with the new motherboard.  this time only the cpu is red on the motherboard  when i turn on the power, everything in the case seems to turn on, but the monitor stays blank.  please help
Easy you forgot to connect CPU power:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
