Budget (including currency): 800
Country: Ireland
Games, programs or workloads that it will be used for: Games like DCS World, Tarkov and spacemarine 2
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I have already bought a second hand 3080TI and I pretty much need to build a PC around it. I have an M.2 SSD in my laptop which I will use for the time being, but otherwise I need to buy all other components necessary.
I have made a PCPartPicker list, please let me know what you guys think, if I have made any crucial mistake that will make this blow up in my face.
Parts List
https://linustechtips.com/topic/1615966-obtained-a-3080ti-for-my-first-build/
Country: Ireland
Parts List
Do you have any links to sites you will be purchasing from?
11 minutes ago, Why_Me said:
I see the motherboard is DDR4, Should I usee that instead of DDR5?
also, How much does the different types of RAM matter?
I messed that one up .... lol. Disregard the board recommendation 😄
Country: Ireland
Parts List
Looks good!
