Upgrading current build to AM5
Go to solution Solved by thewelshbrummie,
1 hour ago, zombiehase said:
How would i go about checking if my PC setup wrong? Being able to upgrade to Windows 11 would give me more time, to get a better upgrade
This Microsoft page is your starting point - install the PC health check app and it will tell you what's wrong.
Your parts support Windows 11 so it has to be a setting not enabled - likely the TPM in the BIOS.
Only OG Zen CPUs don't support Windows 11 i.e. Ryzen 1000 or Ryzen 2000 APUs. Your 3900XT is fine.
Motherboard page says Win 11 is supported. User manual - see pages 28-31. Go to the BIOS and Settings>Miscellaneous>AMD CPU fTPM - make sure that is set to On. It's disabled by default which would block an Win 11 install, so that's where I'd go.
tbh with the parts you already have, I personally wouldn't upgrade until AM6 or whatever the 2026 Intel parts may end up being.
Budget (including currency): about 1000€
Country: Germany
Games, programs or workloads that it will be used for: Gaming
Case:
Fractal Design Focus G Mini
GPU:
Palit Duo RTX 4070 Super 12GB
RAM:
32GB G.Skill DDR4 3600 CL16 2x16GB
Power Supply:
Corsair RM750x
CPU Cooler:
Arctic Freezer 34 esports
CPU:
AMD Ryzen 9 3900XT
Motherboard:
Gigabyte B550M Aorus Pro
Storage:
Two SSDs and a HDD
Im somewhat new to building PCs so i would like to have some opnions if my planned upgrades would make sense.
https://pcpartpicker.com/list/MVDyrM
**CPU** | [AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor](https://pcpartpicker.com/product/3hyH99/amd-ryzen-7-7800x3d-42-ghz-8-core-processor-100-100000910wof) | $358.59 @ Amazon
**CPU Cooler** | [ARCTIC Freezer 34 CPU Cooler](https://pcpartpicker.com/product/ByGxFT/arctic-freezer-34-cpu-cooler-acfre00052a) |-
**Motherboard** | [ASRock B850M Pro-A WiFi Micro ATX AM5 Motherboard](https://pcpartpicker.com/product/FFdMnQ/asrock-b850m-pro-a-wifi-micro-atx-am5-motherboard-b850m-pro-a-wifi) | $189.99 @ Amazon
**Memory** | [G.Skill Trident Z5 Neo RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory](https://pcpartpicker.com/product/CXKKHx/gskill-trident-z5-neo-rgb-32-gb-2-x-16-gb-ddr5-6000-cl30-memory-f5-6000j3038f16gx2-tz5nr) | $119.99 @ Amazon
**Storage** | [Samsung 990 EVO Plus 2 TB M.2-2280 PCIe 5.0 X2 NVME Solid State Drive](https://pcpartpicker.com/product/hpqrxr/samsung-990-evo-plus-2-tb-m2-2280-pcie-50-x2-nvme-solid-state-drive-mz-v9s2t0bw) | $139.99 @ Abt
**Video Card** | [Palit Dual GeForce RTX 4070 12 GB Video Card](https://pcpartpicker.com/product/MYgrxr/palit-dual-geforce-rtx-4070-12-gb-video-card-ned4070019k9-1047d) |-
**Case** | [Fractal Design Focus G Mini MicroATX Mini Tower Case](https://pcpartpicker.com/product/vPp323/fractal-design-focus-g-mini-black-microatx-mini-tower-case-fd-ca-focus-mini-bk-w) | $59.99 @ B&H
**Power Supply** | [Corsair RM1000e (2023) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply](https://pcpartpicker.com/product/fxGhP6/corsair-rm1000e-2023-1000-w-80-gold-certified-fully-modular-atx-power-supply-cp-9020264-na) | $154.99 @ Best Buy
I would like to keep my case, GPU and the SSDs.
Would my upgrades make sense?
Thanks in advance :)
https://linustechtips.com/topic/1615869-upgrading-current-build-to-am5/
2 minutes ago, emosun said:
define making sense , your current machine doesn't seem too incapable.
I generally want to upgrade to AM5, improve performance and upgrade to Windows 11, as my current system isnt able to install windows 11.
I would appreciate advice if the parts work well togehter or some parts would be overkill/underpowered.
your current machine including the board seem to support windows 11 as it has a tpm module.
I don't personally think with the parts you've selected that you will see a 1000$ worth of performance upgrade alone.
https://geizhals.de/amd-ryzen-7-7800x3d-100-100000910-a2872867.html
AMD Ryzen 7 7800X3D €345,98
https://www.techpowerup.com/review/id-cooling-frozn-a620-pro-se-cpu-air-cooler/6.html
https://geizhals.de/?fs=ID-COOLING+FROZN+A620+PRO+SE&hloc=at&hloc=de
ID-COOLING FROZN A620 PRO SE €32,90
Low profile RAM so that the heatsinks don't impede a dual tower cpu cooler.
https://geizhals.de/teamgroup-t-create-expert-schwarz-dimm-kit-32gb-ctced532g6000hc30dc01-a3114019.html
TeamGroup T-Create Expert DDR5-6000 32GB (2x16GB) CL30 €94,67
https://geizhals.de/teamgroup-t-force-vulcan-schwarz-dimm-kit-32gb-flbd532g6000hc30dc01-a3398002.html
TEAMGROUP T-Force Vulcan DDR5-6000 32GB (2x16GB) CL30 €99,99
https://geizhals.de/adata-xpg-lancer-blade-black-dimm-kit-32gb-ax5u6000c3016g-dtlabbk-a3062832.html
ADATA XPG Lancer Blade DDR5-6000 32GB (2x16GB) CL30 €100,26
https://geizhals.de/corsair-vengeance-grau-dimm-kit-32gb-cmk32gx5m2b6000z30-a2998430.html
Corsair Vengeance DDR5-6000 32GB (2x16GB) CL30 €109,90
https://geizhals.de/g-skill-flare-x5-schwarz-dimm-kit-32gb-f5-6000j3038f16gx2-fx5-a2921918.html
G.Skill Flare X5 DDR5-6000 32GB (2x16GB) CL30 €111,58
These psu's are manufactured by Seasonic.
https://geizhals.de/montech-century-ii-gold-850w-atx-3-1-a3483857.html
Montech Century II Gold 850W ATX 3.1 € 94,90
https://geizhals.de/montech-century-ii-gold-1050w-atx-3-1-a3483908.html
Montech Century II Gold 1050W ATX 3.1 €114,90
Sadly my Pc wont let me upgrade to windows 11, thats why i was looking to upgrade. Maybe i have to look into it more, why it wont let me upgrade.
Thanks for the advice 🙂
Thanks for the recommendations:)
Country: Germany
Case:
GPU:
RAM:
Power Supply:
Corsair RM750x
CPU Cooler:
CPU:
AMD Ryzen 9 3900XT
Motherboard:
Storage:
Two SSDs and a HDD
Thanks in advance 🙂
Get a 5800/5700x3d. Maybe even used. A new case! and extra storage if you need it. Much better value. Also your current PC supports windows 11 fully. If not its setup incorrectly.
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
do you have the tpm enabled and are you installing 11 outside of the os?
US Gaming Rig (April 2021): Win 11Pro/10 Pro, Thermaltake Core V21, Intel Core i7 10700K with XMP2/MCE enabled, 4x8GB G.Skill Trident Z RGB DDR4 @3,600MHz, Asus Z490-G (Wi-Fi), SK Hynix nvme SSDs (1x 2TB P41, 1x 1TB P31), 1x WD 4TB SATA SSD, 2x16TB Seagate HDD, Asus Dual RTX 3060 V2 OC, Seasonic Focus PX-750, LG 27GN800-B monitor. Logitech Z533 speakers, Xbox Stereo & Wireless headsets, Logitech G213 keyboard, G703 mouse with Powerplay
UK HTPC #2 (April 2022) Win 11 Pro, Silverstone ML08, (with SST-FPS01 front panel adapter), Intel Core i5 10400, 2x8GB Corsair Vengeance LPX DDR4 @3,600MHz, Asus B560-I, SK Hynix P31 (500GB) nvme boot SSD, 1x 5TB Seagate 2.5" HDD, Drobo S with 5x4TB HDDs, Hauppauge WinTV-quadHD TV Tuner, Silverstone SST-SX500-LG v2.1 SFX PSU, LG 42LW550T TV. Philips HTL5120 soundbar, Logitech K400.
US HTPC (tbc 2025): Win 11 Pro, Streacom DB4, Intel Core i5 14500T, 2x16GB G.SKILL Ripjaws S5 @6,400MHz, ASRock Z790-itx Wifi, Samsung 980 Pro 1TB SSD, Streacom ZF240 PSU, LG TV, Logitech K400.
US NAS (planning): tbc
UK Gaming Rig #2 (May 2013, offline 2020): Win 10 Pro/Win 8.1 Pro with MCE, Antec 1200 v3, Intel Core i5 4670K @4.2GHz, 4x4GB Corsair DDR3 @1,600MHz, Asus Z87-DELUXE/Dual, Samsung 840 Evo 1TB boot SSD, 1TB & 500GB sata m.2 SSDs (and 6 HDDs for 28TB total in a Storage Space), no dGPU, Seasonic SS-660XP2, Dell U2410 monitor. Dell AY511 soundbar, Sennheiser HD205, Saitek Eclipse II keyboard, Roccat Kone XTD mouse.
UK Gaming Rig #1 (Feb 2008, last rebuilt 2013, offline 2020): Win 7 Ultimate (64bit)/Win Vista Ultimate (32bit)/Win XP Pro (32bit), Coolermaster Elite 335U, Intel Core 2 Quad Q9650 @3.6GHz, 4x2GB Corsair DDR3 @1,600MHz, Asus P5E3 Deluxe/WiFi-Ap@n, 2x 1TB & 2x 500GB 2.5" HDDs (1 for each OS & 1 for Win7 data), NVidia GTX 750, CoolerMaster Real Power M620 PSU, shared I/O with gaming rig #2 via KVM.
UK HTPC #1 (June 2010, rebuilt 2012/13, offline 2022) Win 7 Home Premium, Antec Fusion Black, Intel Core i3 3220T, 4x2GB OCZ DDR3 @1,600MHz, Gigabyte H77M-D3H, OCZ Agility3 120GB boot SSD, 1x1TB 2.5" HDD, Blackgold 3620 TV Tuner, Seasonic SS-400FL2 Fanless PSU, Logitech MX Air, Origen RC197.
Tablet: Google Pixel Tablet 128GB
Your PC supports it. I think you just need to enable secure boot and maybe TPM as @emosunsaid.
You can check System Information in windows and post here if you want to.
If I were you, I wouldn't make that upgrade. Just buy a Ryzen 7 5800X3D (or 5700X3D) and enjoy for a few more years. Your PC is more than capable and it won't make any sense upgrading all that.
As the others said, with a Ryzen 3000 (or 5000 also) you can upgrade to Windows 11, if you want to. In the worst case scenario, buy the 5800X3D, format your OS drive and make fresh new install of Windows 11.
Posted (edited)
Thanks to everyone for the advice:)
I was able to activate TPM and check that my PC is able to upgrade to Windows 11.
While Windows still doesnt show me the update, in a few hours it should do so.
I really appreciate your help and am happy that i can save some more money before upgrading my PC.
Edited by zombiehase
